Help Is there any way to quickly change independent volume levels
Hello All,
After 3 solid years, I finally retired my Galaxy Nexus and got a Turbo. Over the years I have been running Cyanogenmod on my nexus. The most current itteration had the feature where when you hit the volume button, beside the slider was a settings icon. When you clicked that you could chose what volumes you wanted to change (ringer, media, alarms). On the turbo though i have to click settings, sound, volume, to adjust them all. Is there any easier way other than an app? I feel like this should be a required feature.
For right now, there is no easier way - just a third party app, perhaps with a widget. I believe that Lollipop will bring a feature as you describe you are used to from the Galaxy Nexus, though.
