I often check Twitter using Twicca. I do this on my LG Volt or my Samsung Tab 2 (7"). Many of the sports links take you first to SportSpyder. Then you must press on the article and it takes you to the blog or whatever where the article is posted.
Almost invariably it takes five to a dozen presses to get to the desired article.
Is this a problem unique to Twicca (I suspect not)?
Or is there something wrong with SportSpyder's programming? If I am on my desktop PC and I need to go through SportSpyder it's no problem whatsover.
Might either of my android devices be the culprit? I tend to doubt that only because they have no other problems that I know of.
What do you think?
What do you think?
