Help Is WHONE is system app
  • Start date Start date
A
Android Question
Guest
Hi dose anyone know if WHONE is system app or what it is. It appeared on my version 4.4.2 phone and has permissions for everything
cheers.
art
It appears even they don't know what it is. Check out this description. Seeing as they refer to the Play Store as Android Marketplace this app was created before 2012 and also it is not listed in the current Play Store. Uninstall it if you can.
whone.cn
Is it a Chinese phone you've got there?
If it's a user app, suggest you remove it. But if it's system, what phone is it, make, model?
