When you're on android. Is connected to the wifi is the wifi are used automatically, or is there a chanse I am using my provider's traffic? I hope wifi is used when it is connected.
Only wifi traffic is used when you see the wifi rays on your status bar, but if for some reason you disconnect from it and the symbol disappears or has a '?' in it, your carrier's network is used
