Help Issue after update to 2.2
sboyle
When I get off a call that is more than a couple minutes long I get a white screen with the green HTC logo and then it goes to my homescreen and says loading. This only takes 30 seconds or so, but it is annoying. Is anyone else having this problem? Also, once in a while I get a connection issue message when opening the sense email app. It says that I am not
connected.
Thanks for the help...
I had a similar issue this morning. After making a call, and hanging up the HTC logo screen popped up for about a second and disappeared to my homescreen. it's only happened to me once so if it happens again i'll investigate
Its been happening to me on and off as well. It tends to occur when I go to the home screen after the phone's been sleeping for a few minutes (though its not consistent and I can't always reproduce the problem).
Just now, in fact, I unlocked the phone and it instantly loaded the GTalk window I had open when I locked the phone. On hitting home, however, the HTC screen flashed for a second or two, and then it displayed "Loading..." as it loaded the homescreen for 15-20 seconds.
Any more insight into this? I am having the same issue -- it has been happening for a few days now. The only apps I loaded this week were the Flash update and Angry Birds seasons. It is driving me crazy. Also, my calendar no longer loads and the weather clock widget sometimes craps out.
I think I figured out my problem (laggy; HTC White Screen; not syncing with HTC Clock/Weather App; not syncing google calender with HTC widget) -- apparently the most recent Flash 10.1 update does not play nice with HTC Sense. Once I removed the latest update, everything started working properly again.
I'm not sure if the task killer question was directed to me -- if it was: I do not run a task killer.
Yes, the task killer question was directed to you, reason I asked is because the screen you are seeing (htc logo) is "sense" starting up, and task killers have a tendency to autokill the process causing you to see that screen.
I've noticed this too. I think it had something to do with the most recent system update. It's a bit buggy. I doubt it is flash unless there is proof out there of this.
