ISSUE: 'Bleutooth HCI snoop log' will NOT stop logging
AVoit64
I use the Tablet Lenovo TB-X704V for streaming music via a Bluetooth device.
The Android Version is NOUGAT 7.1.1
The problem is that despite the fact that under 'Developer Options' the button for 'Enable Bluetooth HCI snoop log' is OFF - I repeat, the button is 'OFF' - the device keeps on logging and producing an alarming number of 'btsnoop_hci.log' files (4Gb worth in 2 days - because I stream music all day).
To stop the device from running out of 'Storage space' i have to keep deleting the files. I would like to solve this ridiculous problem.
- Before this problem began to occur the 'Enable Bluetooth HCI snoop log' button was NEVER turned ON. In other words the device began logging HCI snoop files WITHOUT enabling Bluetooth HCI snoop log.
- This problem was NOT solved by RESETTING (factory reset) the tablet.
Your help is greatly appreciated.
Thank YOU
try putting it in safe mode to determine if a 3rd party app is causing it. if it still happens in safe mode and a factory reset does not fix the issue, then i have no clue what is going on or how to fix it.....maybe get a new device(just kidding.....but not really;))
ocnbrza, thanks for the response.
I can not play the Music Streaming app in safe-mode, so it seems to me that this issue can not be tested this way.
maybe try a different streaming app. if nothing happens in safe mode, then it most likely occurring from the streaming app. try a different one to see if it only happens just with that one app.
