Issue with android ICS
camsarria
Greetings,
I got a smarthphone with android ICS, and im having a small issue
Basicly the phone has 512 megs internal memory, 2 gig aditional memory and a SD card slot where i fitted an aditional 2 gig.
On the file manager i see SD1 (identified as SD card) and SD2 (the sd slot one, wich is identified as usb storage)
I am having trouble installing apps on SD2, i only got option to install on the internal memory and SD1, not SD2.
Do you got a solution for this?
Best regards
Carlos
Unfortunately it isnt possible to install apps on the external sd card in ics, unless you are rooted.
