arbor12345
I have downloaded over 10 different audio equalizers and I have the same issue with all of them... They only work with select apps and apps like pandora and grooveshark they do not work with... I want an equalizer cause pandora sounds like garbage without one, I use cheap headphones, but with the equalizer they are actually pretty good, this I know because the equalizers work with tune in radio and it sounds good.
has anyone else had this problem and were you able to fix it?
