Help Issue with Data Manager
pmod
Hi,
I've been using Defy from last weeks now. Must admit, its a good phn though it has tendency to get really slow at times...
Coming to the problem... I usually switch all data connections on defy when I'm online frm mah lappie wch is d case usually ven entire day im in office. But since yesterday, data connection resumes on its own within couple of seconds after disconnecting it. Tried multiple times..even restarted the phone..but data connectn is own by default... its not switching off....
Is thr a bug in d OS ...or sum app is d cause..or may b a virus causing it?
Please help. Thanks in advance. :)
I had a same problem after installing a APPS for data connection management. Uninstall the apps did not help. Eventually I had to do factory reset. After this reset the problem resolved.
