Help Issue with Pandora stopping
I seem to have the issue with Pandora stopping after every song when the screen is off and i am on wifi.
I changed the wifi policy to never and it still does it.
Is there anyway to fix this?
I would try to uninstall and reinstall as it sounds like this issue isn't happening to anyone else (at least it isn't happening to me and I haven't seen anything regarding this issue)...
I take the train on the ride home to/from work and I have pandora turn off on me sometimes. I will fall asleep and wake up to no music playing. Using 3G, in a decent area for 3G reception. Under normal circumstances, I can have pandora stream without a hitch, just sometimes it turns off and I have to hit play. Mid song it will happen.
What the hell? I really need to read my post before I post. I think I meant its only on wifi. Sorry about that. I will proof read from now on.
so anyone experiencing this issue?
Just tested it and it only does that on WIFI, works fine on 3g. Really strange.
It does that because pandora implemented a little popup that asks you if you are still listening because they dont want to play to an empty room. Havent timed it but im sure thats what your issues are. So far i havent found a way to disable it.
