plamenvelikov023
Hello Android Experts!
Im experiencing some strange behavior with my SD Card Memory..
so the problem is when i insert my SD CARD into my Android device,and go to settings to check is everything is okay,and its okay! BUT..! when i leave the phone or whatever,and come back,i noticed that the phone comes unrensponsive to touch,or when i touch something it has some delay..and freezes somethimes n all apps no matter are they on the sd or internal .. they cannot be accessed! .. i cant access even the file manager .. for example ES FILE EXPLORER.
This problem i expirience on STOCK ANDROID FIRMWARE 5.0 L.
so i decide to root and flash a new rom!.. the result-->absolutely same..
i decide to flash another rom which i am right now.! The result--> not the same but,somethimes the sd card is readable and it shows the amount of storage,but somethimes is not..its very annoying and cant access nothing on the phone even the dialer pad.. and suddenly reboots.. unexpectly .. the PROBLEMS DOWN BELLOW!
