Root Issues after OTA to ICS
Just wanted to see if anyone else is having issues since the OTA to ICS over the past couple of days? Since the update my Rezound reboots if you use Google Maps, or Navigator, also Bluetooth is acting really strange. I am following Scottys guide for flashing firmware and running back to Gingerbread.
might also try runnig an ruu,and doing a "clear storage" or "factory reset" from hboot.
could be your personal data didnt get properly "re-organized" after the update... the frameworks are very different between ICS and GB so wiping the slate clean may fix alot of issues.
You are going to have problems with the newest maps and OTA ICS. You will either have to side load an earlier version of it for now until they fix it or if you want to update to the latest ICS build out there, this fixed the maps issue for me. Not sure about the blue tooth issues
