These are what I've noticed so far:
1. Battery drains faster- used to last 1.5day, now maybe 1
2. More heat when using apps/browsing- Gets pretty warm when using most apps
3. Maps reboots phone- Wide spread issue
4. Facebook keeps logging out and losing sync
All can be fixed with a factory reset.
Also with you map problem, just uninstall the updates and this will fix it.
1. This seems to vary greatly by user and possibly hardware revision, personally I have noted almost the same to increased battery life on both of my Rezounds, although it did take several days of use, initially it seemed to go through battery much quicker. Most people who have tried 4.3.605.2 have noted the improved battery life over the current ICS release.These are what I've noticed so far:
Indeed, this is not completely true for everyone, but most people who have had issues with the OTA release of ICS who have done a factory reset have improved performance and less issues, but not everyone, so the original recommendation to this was probably correct, it would have been my first recommendation.Not completely true. I've performed two factory resets since the update and still have the overheating issue, as do many others. The upcoming update to the update is reported to help the heating problem caused by ICS.
ICS does not have provisions for this built-in like Gingerbread, but there are lots of apps in the Play Store that will give you this functionality back, you can search the Play Store and will find lots of ICS Volume Control apps, but I would try Volume Control + first.on my rezound i can no longer put my notification sound on vibrate while leaving my ringtone on high. how can i fix this?
