ayrshiredude
Am currently running Darkys rom 10.1 and having a few problems with it wondered if anyone could help.
I have it running with ADW launcher and find it very sluggish. Constantly sticking and freezing. Not sure if adw launcher is the isuue here though. Also find some apps that require internet access will work fine then after you close them if you reopen it then it won't access the net. You seem to have to go into the task manager and stop it then try again and it works.
Quite often when you type things you can type a whole word with nothing displaying before the work just appears. Seems to be quite laggy.
Does anyone else have these issues?
Thanks
Thanks
