Issues with linking to computer and file transference *pls help*
So, I have had a multitude of Android based phones starting with the original Droid, Evo, Photon, now Galaxy S2 (Sprint). On every Anrdroid phone, except now with latest updates to the Galaxy S2, when I linked to my PC the phone would show up as a removable drive (e.g. K:/) and I could drag file to and from the phone with such ease. I essentially used the phone as a flash drive and it worked just as seamlessly as a flash drive. There were no delays when navigating through the phone's folders and file transference to and from the phone was quick.
For the first couple months after I purchased the Galaxy S2, linking to the computer was actually the same as it always had been....a removable K:/ drive would pop up when I linked the phone and transferring files (even bigger ones) was easy. However, at some point (may be related to a firmware update, or Android version update, not sure), when I linked to the computer it started downloading all these drivers and I noticed Samsung/android related updates taking place through Windows 7 Updater.
Now, instead of a separate drive letter showing up when linking the phone to PC, it actually shows up under "Portable Devices" with a little phone icon named "SPH-D710." Also, the phone's notification/task list shows the link to computer as "MTP-Connected" (pretty sure it said something else when it used to connect as a removable drive).
Anyways, all these minor changes would be fine with me had the performance not taken a nose dive. Now it takes much longer on the PC to load up and navigate through the phone's files folders....especially the larger folders with pictures/videos/music. The worst part is phone to PC (and vice versa) file transference. When I try and transfer the larger video files from the phone's folder to my PC desktop it sometimes says something along the lines of "The requested resource is in use." Sometimes, if I wait a few minutes, I can eventually transfer the file to my PC (still takes much longer than it used to)....however, other times, such as now, I cannot transfer the files at all. The same "Request resource is in use" keeps popping up and I cannot transfer the file!!
This is crazy...whatever improvements they were trying to make, did not only not work, but really screwed everything up. Is there a way to deactivate all those "new" drivers/updates and have the phone show up again on the computer as a removable drive (like how a flash drive shows up)? Not sure if this is Samsung specific, or now an issue with all Android phones.
Any help will be extremely appreciated.
Go to menu>settings>wireless and network>USB settings. The device appearing in portable devices means it has been set to either Kies mode or Media mode. To appear as a portable drive it needs to be in Mass storage mode. Note that if you have carrier branded firmware some options may have been changed or removed.
thanks! that was very helpful! here's how I finally got it to connect to mass storage...
1) Disconnect micro USB input from phone
2) (As per your instructions) go to menu->settings->wireless & network->USB Utilities
3) Press "connect storage to PC" button
4) Connect micro USB input into phone
5) Click "Connect USB Storage" button
The key was to disconnect the micro USB before going through the motions...kind of a pain, but glad it is working now! I never knew the difference between media/Kies mode and mass storage! Kies is worthless in my eyes...only good part about it is the wireless aspect, but even that is impractical given how long it takes everything to load.
