Issues with Navigation
I use Google Map for navigation and of late I find that the directions are quite slow and there is a lag between the actual location and what the voice navigation says. Sometime a good 5 minutes delay is encountered which makes the navigation useless.
The location in the map is correct it is only the problem with the voice prompt where there is a delay.
The phone also gets too hot and I am wondering if these are related.
There is no problem with other application.
Do I need to replace the battery and will this help ?
Have you tried clearing data for Maps? It could be getting bogged down in its own cache.
If it's overheating, that could be causing the issue too...
