iSyncr duplicating files when syncing
Geese1
I bought Isyncr based on the recommendations on this site, and while it seems to be a good program overall, I'm having a problem with it duplicating files which I hope someone can help me with.
So the initial sync went fine. I only have one actual playlist of soundtracks, while all the rest of my music is just on it's own and not in any playlist. I chose to sync my music library and the soundtrack playlist from the first tab when selecting what to sync and everything worked beautifully.
The problem is when I add new music to iTunes, and then go to sync again using iSyncr it starts to copy my entire music library over. I end up having to cancel it and then go into Poweramp (my music player of choice) and delete the duplicate tracks.
I thought iSyncr would be like iTunes in that it would just see the new or changed tracks and sync those, not my whole library all over again.
I have a feeling it's just a setting I don't have right, but I'm not sure what to do. The only option I see is to choose each new album or track individually and sync it over that way, but I thought the program was supposed to be all automatic and I wouldn't have to resort to that.
If anyone has any ideas on how to get this straightened out, I'd love to hear it!
You are correct, iSyncr is designed to automatically update your playlists. The program is not working correctly for one reason or another.
I would love to ask you a few questions and get to the bottom of this. Would you drop me an email at isyncr@jrtstudio.com so we can find a resolution to our issue?
