ericdouglas17
Hi all,
I sent this e-mail to the developer earlier, but thought someone here might have had a similar issue. I'm using a Samsung Vibrant, Android 2.1 update 1.
I purchased the PC version of iSyncr last night, and have attempted to sync my iTunes library numerous times. Each time, the same thing happens.
1) Installed iSyncr to SD card
2) plugged in USB, and select the option to mount my card for copying files.
3) PC recognizes card, and opens it in Explorer.
4) run iSyncr.exe
5) iTunes is already open, and iSyncr finds the playlists.
6) I select a playlist of roughly 1000 songs, and click Sync.
7) It copies all files to the device, keeping the folder structure as I have it in iTunes.
8) When it completes, the iSyncr window clearly shows that there is now 25.55GB free (previously was 30GB, it's a 32GB card)
9) Windows Explorer confirms this, showing that the contents of the "syncr" folder is about 4.7GB.
10) I click "Eject" in windows explorer, and unplug the USB.
All of a sudden, there are only 156 files on the SD card. All of the folders are still there, but they're all empty, except for a few. When I plug the phone back in, Windows Explorer shows the contents of "syncr" as less than 1GB. See attached screenshots that demonstrate what I'm talking about.
Any ideas? This sounds wacky, I know.
Thanks!
Eric
4) run iSyncr.exe
Thanks!
Eric
