E.g. the calendar, contacts? So I have to register with such service to back up? Are the back ups done automatically then or do I need a special app / programm?Google photos is used to backup all of your photos and videos.
Google play store is used for all of your apps
Or on a hard drive, I guess.Everything else can be backed up manually using a file explorer and a external SD card.
Actually I am not sure, I download the apps without being logged in or registered, there is a message shown always when I download a new app to register or such.Well you need to use a Gmail account for all of your apps. That is what Google play store is used for.
Don't you already use one?
Sounds like it is not a free one.There's an app called Super Backup Pro in the play store that will backup all of your contacts, apps and SMS messages.
Sorry, I do not understand, what is the connection to the Smartphone / backing up the Smartphone?If you use Google Chrome as a browser, it automatically backs up your bookmarks for websites.
So one has to do several back ups (for photos, calendar, etc. or one? I do not use the Google calendar but another app.Google photos is linked to your Gmail account, so if you login on your pc you can access everything there also, no hard drives needed.
Google calendar automatically saves your tasks.
It is not possible to back up my data from my mobile phone:
"fehlgeschlagen" means "failures" / "failed":
Restarting the Notebook, Smartphone, plugging in and off the plugs do not help.
Yes, just tried again with another cord, the original, this message was shown:
It is shown quite often, saying something like communication between devices failed.
No, it hasn't worked ever. After the last Win 10 update or the one before or so a back up is at least performed / treid, before not even that has happened.Has it ever worked?
No, not that I would have noticed it. Just connect it via cable, give access and back up. When plugging in the plugs that program, Xperia Companion, opens and one has to click on back up.Are you supposed to set the phone in a certain mode or something?
