Help Itunes note 4 KIES will not work
I have tried and tried so many programs but cant find one that works properly. I have 2 notes. a note 4 and note 2 also have an Iphone 4s. I have iTunes for my music lists and it is huge and I just want a program to use that will install it on my Note 4 SD card and not to the phone. The closet I got was Wondershare MobileGo and it will only install my playlist to my phone and not the card. I have been reading many forums and have had no luck... Can anyone please help me out? Note 4 version 4.4.4 with newest update and NOT rooted.
I use doubleTwist AirSync on my Note 4. It syncs my iTunes library wirelessly to my phone and you can choose between internal and micro sD card storage. You can also pick which playlists you want to sync.
The only downside is that, if your iTunes library is large, the wireless syncing takes a very long time the first time you do it. After that it only looks for changes so the process speeds up considerably.
You might want to look at iSyncr also. The free version only allows you to sync one play list at a time with only 100 songs per playlist but the paid version removes those restrictions.
Here is the link to the free version on the play store.
https://play.google.com/store/apps/details?id=com.jrtstudio.iSyncrLite
I 2nd iSyncr. Been using it for years and it syncs your iTunes playlists exactly as they are. Plus you can do it over Wi-Fi so you don't have to mess with cables.
