iWay SMS Controller v1.1.2 {FULL}
PLS NOTE: This app was created by me(vishnu007) :) Please download from Google Play and give me ratings and feedbacks in it. I have also attached APK file for those who are downloading from PC. Pls post ur feedback below
Description:
Welcome to iWAY SMS, now control your phone which you have left at home. Many people have more than one mobile with them. One may be for work and the other may be for personal use. But there are times when we carry only one mobile with us and the information from other mobile may be needed urgently. For instance, consider the situation in which a business man is on a vacation and he needs the number of his client immediately but he has left his official phone (phone without internet connection) at home which is locked. In such situation we can use our app and send an SMS query to the Android phone left at home and get back the required information automatically via SMS. Hence our app acts as a communicating medium for transferring small piece of information between an Normal mobile and Android Mobile
Download from Google Play/Skydrive/DropBox:
https://play.google.com/store/apps/details?id=com.vishnu.smartsms
http://sdrv.ms/17qwFz8
https://www.dropbox.com/s/dqtgyw9od6yja2r/iWaySMS v1.1.2.apk
Screen Shots:
[video=youtube;xZ8KFiOps-I]http://www.youtube.com/watch?v=xZ8KFiOps-I[/video]
***IMPORTANT***
Texting Replacement Apps:
If you have an SMS replacement app (Handcent/Go SMS). The workaround to fix this is very similar for both apps.
Go SMS - Open Go SMS, hit 'Menu' and click 'Settings'. Switch to 'Advanced' mode at the top. Go to "Other setting". Uncheck "Disable other message notification".
Handcent SMS - Open Hancent, Hit 'Menu' and select Settings, Click Application settings, then Default Messaging Application, Set this to 'Disable'.
Read the following instructions carefully, you can read it any time from the app by clicking Menu->Get Help
Note: A random number is generated as default password, it can be changed from Menu->Settings->Enter Password
Situation 1: Both Sender & Receiver are Android users with iWAY SMS installed
Just use the User Interface provided in our application to retrieve the necesary content
Situation 2: Sender is not an Android User/ dosen't have iWAY SMS installed. Sending an SMS in the following format gives you
an appropriate reply
1. Retrive Contacts from other mobile
iWAY CONTACT contact_name password
eg. iWAY CONTACT bala 1234
2. Change Sound profile of other mobile
iWAY PROFILES profile_name password
eg. iWAY PROFILES SILENT 1234
iWAY PROFILES VIBRATE 1234
iWAY PROFILES NORMAL 1234
3. Retrive Call Log from the other mobile
iWAY CALLS call_type password
eg. iWAY CALLS INCOMING 1234
iWAY CALLS OUTGOING 1234
iWAY CALLS MISSED 1234
4. Retrive Contact name for a given phone number
iWAY PH2NAME phone_number password
eg. iWAY PH2NAME 9344450844 1234
5. Retrive the Battery status of other phone
iWAY BATTERY status password
eg. iWAY BATTERY status 1234
6. Retrieve recently received SMS from other mobile
IWAY SMS type password
eg. IWAY SMS inbox 1234
IWAY SMS sent 1234
