Jacked pack
Rgarner
Android Expert
The zipper keeps separating. I can't keep the pack shut. Is there any way to fix it? Yes, it's not beautiful but I was able to use it until recently.
I would suspect that the closer is worn to the extent that it is no longer pulling the two sides together enough to fasten them. You might try taking a pair of needle nosed pliers and gently squeeze the bottom of the closer a bit. Making the space the two sides must pass through smaller from side to side might help.
Disclaimer: I've tossed and not repaired worn out zippers.
