Apps Jackson mapper, Spring Android and https not marshalling
Vishenzo
I m actually trying to developp a little application which has to receive data from a REST secured API. I m using Spring Android (Spring for Android) to make it in an easy way.
I have used this framework before on standard HTTP REST API and it worked great. But now, it seems that I have a problem with:
this.mRestTemplate = new RestTemplate();
this.mRestTemplate.getMessageConverters().add(new StringHttpMessageConverter());
this.mRestTemplate.getMessageConverters().add(new MappingJackson2HttpMessageConverter());
Explanations :
If I add the StringHTTPMessagerConverter I can get the full JSON result on a String format on HTTP & HTTPS
If I add the MappingJackson2HttpMessageConverter, I can get the json and a full object marshalled corresponding(on HTTP), but on HTTPS, it seems that the code is blocking on :
ResponseEntity responseEntity = mRestTemplate.exchange(BASE_URL + ws, HttpMethod.GET, getRequestEntity(), ContainerAnomalie.class);
NB : ContainerAnomalie extends ArrayList NB2 : My API Key is okay, I can get the full JSON in a String object, and I can display it on a browser using the request URL
There are no errors displayed in the logcat...
Do you have an idea ?
Thanks for advance,
