Apps Java class with parameter
wavix
Hi!
I have this DownloadJSON class initialized on onCreate with
Java:
new DownloadJSON().execute();
Java:
@Override
protected Void doInBackground(Void... params) {
    arraylist = new ArrayList<HashMap<String, String>>();
    jsonobject = JSONfunctions.getJSONfromURL("http://www.domain.com/json2.txt");
    try {
        jsonarray = jsonobject.getJSONArray("worldpopulation");
        for (int i = 0; i < jsonarray.length(); i++) {
            HashMap<String, String> map = new HashMap<String, String>();
            jsonobject = jsonarray.getJSONObject(i);
            map.put("rank", jsonobject.getString("rank"));
            arraylist.add(map);
    } catch (JSONException e) {
        Log.e("Error", e.getMessage());
        e.printStackTrace();
    return null;Below, depending where users clicks, I want to change jsonobject = JSONfunctions.getJSONfromURL("http://www.domain.com/json1.txt");
Something like this:
@Override
    protected void onPostExecute(Void args) {
        listview = (ListView) findViewById(R.id.listview);
        adapter = new ListViewAdapter(MainActivity.this, arraylist);
        listview.setAdapter(adapter);
Java:
Java:
public boolean onNavigationItemSelected(MenuItem item) {
    int id = item.getItemId();
    if (id == R.id.itemone) {
        new DownloadJSON().execute("http://www.domain.com/json2.txt");
    else if (id == R.id.itemtwo) {
        new DownloadJSON().execute("http://www.domain.com/json3.txt");
    return true;
How I can obtain this? I can't figure out how to do it.
Thanks!
