Java exploit vulnerability in Android?
Hi,
on a Android device you do not need to worry about this specific problem. Android uses its own security and does not run standard plain java apps and applets but uses its own classes derived from suns java. The main risk is for systems such as PCs using java in browsers and users accessing malicious html sites using pc browsers. An update can help to control the problem. See attachment.
Regards golpe
