Java as in the SDK or runtime? No there isn't one for android.
I dont get it. What do you need Java for? Are you trying to run Java applications on android? If you want to do online banking, can't you just log on to website?
Or find if there is a mobile version of the site. Even so, I have never seen a login use a Java applet unless based in JavaScript. You might want to go to your browsers setting and make sure JavaScript is enabled. That or maybe able to try dolphin browser. They try to develop that to substitute for the things android lacked. For ex. Before flash was implented into the marketplace, dolphin browser allowed you to see it through their server.
OK, I am sorry. Thanks for the clarification. Still, I would think that there would be some sort of alternate site of or those that don't have it. Oh well, you might still want to attempt to use dolphin browser to see if there servers will supply the necessary Java runtime.
