The apps you run in Android are based heavily on Java. Hence why Oracle has ongoing lawsuits pending with Google. You might have better chance of putting the java code through the Android SDK and building an APK.
If I'm understanding correctly, what's really required is a browser with a full Java runtime engine supported so fantasy football mock drafts (as found at ESPN and I think CBS) will work.
One app that may help is Pro Football Weekly NFL Draft App for iPhone, iPad, and Android | Sports Geekery
There may be others, and I've assumed football because of the timing. This happens for MLB And NBA, too.
OP, let me know if I'm getting the idea, and if so, I can suggest the sports section of our Lounge as fantasy football seems to be heating up already there.
Only way I've seen to run Java apps without being able to crank them through a development cycle -
App Runner
