java.lang.string error
akhil0007
please help in getting rid of this error...
Please show all the code for class RegisterActivity.java. Need to see the declaration of variable loadingBar.
The error indicates that either a) There's no method setTitle() defined or b) you're using the wrong method parameters for this method, on the class relevant to variable loadingBar.
package com.example.anew.mychat;
import android.content.Intent;
import android.support.annotation.NonNull;
import android.support.v7.app.AppCompatActivity;
import android.os.Bundle;
import android.support.v7.widget.Toolbar;
import android.text.TextUtils;
import android.view.View;
import android.widget.Button;
import android.widget.EditText;
import android.widget.ProgressBar;
import android.widget.Toast;
import com.google.android.gms.tasks.OnCompleteListener;
import com.google.android.gms.tasks.Task;
import com.google.firebase.auth.AuthResult;
import com.google.firebase.auth.FirebaseAuth;
public class RegisterActivity extends AppCompatActivity {
private FirebaseAuth mAuth;
private Toolbar mToolbar;
private ProgressBar loadingBar;
private EditText RegisterUserName;
private EditText RegisterUserEmail;
private EditText RegisterUserPassword;
private Button CreateAccountButton;
@override
setContentView(R.layout.activity_register);
mAuth = FirebaseAuth.getInstance();
mToolbar = (Toolbar) findViewById(R.id.register_toolbar);
setSupportActionBar(mToolbar);
getSupportActionBar().setTitle("Sign Up");
getSupportActionBar().setDisplayHomeAsUpEnabled(true);
RegisterUserName = (EditText) findViewById(R.id.register_name);
RegisterUserEmail = (EditText) findViewById(R.id.register_email);
RegisterUserPassword = (EditText) findViewById(R.id.register_password);
CreateAccountButton = (Button) findViewById(R.id.create_account_button);
loadingBar = new ProgressBar(this);
CreateAccountButton.setOnClickListener(new View.OnClickListener() {
@override
public void onClick(View v) {
String name = RegisterUserName.getText().toString();
String email = RegisterUserEmail.getText().toString();
String password = RegisterUserPassword.getText().toString();
RegisterAccount (name, email, password);
private void RegisterAccount(String name, String email, String password) {
if (TextUtils.isEmpty(name)){
Toast.makeText(this, "Please write your name", Toast.LENGTH_LONG).show();
if (TextUtils.isEmpty(email)){
Toast.makeText(this, "Please write your email", Toast.LENGTH_LONG).show();
if (TextUtils.isEmpty(password)){
Toast.makeText(this, "Please write your password", Toast.LENGTH_LONG).show();
else{
loadingBar.setTitle("Creating New Account");
loadingBar.setMessage("Please wait, while we are creating acccount for you.");
loadingBar.show();
mAuth.createUserWithEmailAndPassword(email, password).addOnCompleteListener(new OnCompleteListener<AuthResult>() {
@override
public void onComplete(@NonNull Task<AuthResult> task) {
if (task.isSuccessful()){
Intent mainIntent = new Intent(RegisterActivity.this, MainActivity.class);
mainIntent.addFlags(Intent.FLAG_ACTIVITY_NEW_TASK | Intent.FLAG_ACTIVITY_CLEAR_TASK);
startActivity(mainIntent);
finish();
else {
Toast.makeText(RegisterActivity.this, "Error Occured Try Again....", Toast.LENGTH_SHORT).show();
loadingBar.dismiss();
Code:
    [USER=1021285]@override[/USER]
        else{
            loadingBar.show();
                        finish();
                    else {
Your object loadingBar is ProgressBar. Android ProgressBar does not have methods setTitle() and dismiss();
To "setTitle", If you want to show some title above loadingBar, just add TextView in layout and use setText() method.
To "dismiss", if you want to hide loadingBar, use setVisibility(Visibility.INVISIBLE) method.
