Run JavaScript scripts on your Android devices. All android API is exposed to JavaScript: scripts can create views, process activity events, create threads, and do almost everything a java application can do.
The Rhino JavaScript engine is used for script execution. Scripts also can run with a JavaScript console.
https://play.google.com/store/apps/details?id=serakont.android.js
