Root JB AOKP rom
Bugly
Android Expert
There is a AOKP JellyBean rom available if anyone is interested. It isn't fully developed yet, as the front-facing camera FCs in video, Bluetooth is a bit wonky and HDMI/Webtop isn't rotating correctly.
Everything else seems pretty legit, I'm having issues with my Elecont weather app, but most other stuff is working fine, probably just an issue with not having developed the apps to work on jellybean.
If you're interested in this, you need safestrap 2.11 or newer, (I'm on 3.05) and root (obviously). Plus, you'll need to have an account with droid rzr.com to download. (I am not affiliated with this webite, just relaying the message, since I'm sure someone may be interested in this as much as I was.)
Black Widow 4.1.2 ([Aokp/cm10 Roms]) 10/26/2012 - DroidRzr.com
black widow is a custom rom based off of aokp cm10. those who want the full stock cm10 builds or aosp can find them in the hash of code thread in my bionx dev section (link in sig)
Black widow is a pretty good rom tho
So far it has been stable and smooth, the theme is really dark, so if you don't like dark themes, this definitely is not for you.
Thanks, Biotic, for mentioning the fact there are more ROMs on CM10 out there! I will be messing around with them now that I have Safestrap 3.05, which has multi-ROM capabilities!!!
