JB phone freezing
Argjent
This has been happening ever since I got Jelly Bean, the phone stops responding, after a while it reacts to all my previous commands if I am lucky. On other occasions I will have to pull out the battery and get stuck on the black GT-I9100 screen. From this point on the only thing I can do is get into CWM recovery I installed via the PhilZ kernel and do a factory reset which then boots up my phone into the right state.For 2 months now this happened 3 times. Once I wiped data, cleared Dalvik cache and wiped cache partition just to make sure, but the problem reoccurred again, cleared all the 3 options as I stated now and In the present state the phone is working fine, but I am afraid and sure that it will happen again. So is there anyone kind enough to guide me out of this mess.
Info: I9100 with Nordic Jelly Bean XWLSD_OXX from February
Since you are rooted, I would suggest the, "Full Monty", to sort out your problems. Perhaps you might also like to flash the latest Nordic Countries release, LSN, while you are at it.
