krishnaveni
am successfully finished login form in android using mysql connection via jdbc in java...its successfully worked in my localhost...but development site its not worked...the following error is displyed.
why dis error is occurred.give me some solutions. if am running localhost means my sql query is
if am running development site means my query is:
dis development site username,password,database name and url all r correct only...then why dis error is occured....give me solutions...
Code:
java.sql.SQLException: Unable to connect to any hosts due to exception: java.net.SocketException: java.net.ConnectException: Connection timed out: connect
** BEGIN NESTED EXCEPTION **
MESSAGE: java.net.ConnectException: Connection timed out: connect
STACKTRACE:
at com.mysql.jdbc.StandardSocketFactory.connect(StandardSocketFactory.java:143)
at com.mysql.jdbc.MysqlIO.<init>(MysqlIO.java:225)
at com.mysql.jdbc.Connection.createNewIO(Connection.java:1805)
at com.mysql.jdbc.Connection.<init>(Connection.java:452)
at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:411)
at java.sql.DriverManager.getConnection(Unknown Source)
at com.retrieve.retrieve.main(retrieve.java:15)
** END NESTED EXCEPTION **
at com.mysql.jdbc.Connection.createNewIO(Connection.java:1875)
Code:
String user = name.getText();
String strpass = pass.getText();
try {
Class.forName("com.mysql.jdbc.Driver");
} catch (ClassNotFoundException ex) {
Logger.getLogger(jdbclogin.class.getName()).log(Level.SEVERE, null, ex);
try {
Connection con = DriverManager.getConnection("jdbc:mysql://localhost:3306/login", "root", "");
Statement st = con.createStatement();
String query = "SELECT password FROM customers where login='"+user+"'";
System.out.println(query);
ResultSet rs = st.executeQuery(query);
Code:
try {
try {
Connection con = DriverManager.getConnection("jdbc:mysql://dev.sasas.com:3306/login", "asas", "sass");
String query = "SELECT password FROM xcart_customers where login='"+user+"'";
