Hi everyone,
I'm fairly new with my Android Tablet, it is a WM8850-mid.
It has Android 4.0.3 installed, I just start using it and found out Netflix does not works, it installs successfully but when you try to use it the touch screen does not responds.
Well based on my Netflix problem, I was decided to upgrade the Android version on it to Jelly Bean (and see if that solves the problem), but it turns out the System Update option is not available
so I haven't found a way to upgrade it.
Does anybody knows where can I found the Jelly Bean version for the WM8850-mid table and where could I find some instructions on how to install/upgrade my tablet?
Thanks.
so I haven't found a way to upgrade it.Does anybody knows where can I found the Jelly Bean version for the WM8850-mid table and where could I find some instructions on how to install/upgrade my tablet?
Thanks.
