I wish I could customize the apps on the lock screen. I would switch to email and some others.
I have been running JB for a few days now. I haven't noticed any major improvements compared to ICS. There are a few cosmetic changes and the notification drawer adds more functionality. Speed is the same as ICS for me. I never had lag in ICS, though. The Circles Widget is fixed to keep saved settings for notifications.
Some of my apps don't like JB. I may revert back to ICS and go to JB at a later date when more development is done for JB.
Interesting - I haven't noticed any non-functionality with old apps yet, but then I also haven't played with most of them. What apps specifically 'don't like' JB? It would helpful if we identified the apps that don't work as well with JB as they did with ICS.
I agree for the most part - not much improvement but didn't have an performance issues with ICS anyway.
How do you change which applications you can use? I use a different dialer, camera, and txt app. When I got the phone on ICS I was able to change them but when JB installed it reverted them back.
Got mine last night. I noticed better screen/app transition speed on stock launcher. But it's still not as smooth as my Gnex was with stock JB. Razr HD seems to have a lot of bloats loaded to memory though its UI looks close to stock android, so maybe that's why it feels more laggy than Gnex. But in Nova launcher RHD is very smooth.
Another con I noticed on RHD is that it doesn't allow to disable some verizon bloats like verizon video, VZ navigator, etc. I can only force close them in all section of app setting. Is there any way to disable verizon bloats without root or force closing them is just like disabling?
You might need to reset up your default apps for each of those. You could also try Default App Manager from the Play Store.
When you were using your Gnex were you using the stock message app? When I had my Gnex with rooted Jellybean I thought there was a quick reply option built into the stock message app. I guess it could've been a ROM thing but I was looking forward to so I could ditch Go SMS.
I was using stock message app in Gnex on JB. it had quick reply in the app.
Thanks to lowboydrvr for tip for disabling verizon bloats. Will give it try.
