Dr Hack
Hello,
Few Questions
Scenario: Flashed Jellytime R24, was running CM7.2 on HTC DHD
Question 1: The total Ram Shows as 594MB and Free RAM is 170MB , with only basic Apps (which run in the backgroud i.e G+,Whatsapp,Gmail,Email etc) is that Normal? on CM7.2 it was around 620MB and had 200+ free RAM without running anything, How Much Free RAM you people have without pressing the kill apps button? and wont it hinder if i run heavy Apps, or Games , like just doing messaging etc i am sitting on 90MB free RAM ..
Question 2:If i go into Settings of Gallery it always appear BLANK , Always .. ?
Question 3: Will it be Safe to remove the Launchers with came with the ROM i.e Nova Launcher etc ? if Yes have to remove from Folder ?
Answer Got the Answer, its A Yes
Question 4: Where to adjust the Notification lights for messages and missed calls etc?
Question 5: When I get a new message the mobile screen gets on and the notification light blinks, but the screen never turns off and if another message is received before i have touched the mobile the blinking light also stops .. kind of strange behaviour ?
Question 6: I have some questions specific to Applications behaviour with this ROM can i ask those here aswell ? (Mostly related to Go Sms Pro and GO launcher)
Thanks in Advance
Few Questions
Thanks in Advance
