Jorte sync problems
I have an HTC Desire and have been using Jorte calendar app. It worked fine for several weeks then it quick syncing correctly. Not sure why this is happening. I am syncing it with my 2007 Outlook. I have a gmail account and I am using Google Calendar Sync. on my computer. Wondering if anyone has the same issue. I can't figure out if it's a phone problem, a problem on my computer software end, or something else. I have searched the web and can't find an answer. I have also unloaded and reloaded everything with the exception of Outlook.
Hey there,
I'm having the same problem and I don't know why either. I'm on a Galaxy S and the problem happened the same way; Jorte tasks worked really nicely for a few weeks and then it just quit syncing. I'm afraid I don't have any more idea than you, about how to fix it. If you figured it out since posting your message, can you enlighten me, please?
Good luck!
