carlolosci
Hi there I have a problem with Jorte.
If export an EMPTY calendar as a CSV and then import it back to Jorte, it'll work.
If I do the same
with a calendar which has even just a single event inside of it, things won't work so well. It'll successfully export the calendar as a
CSV, but as I go ahead and try to import it back into Jorte, an error window pops up that reads: "Failed to import file".
I'm using Jorte Calendar 1.4.6 on Android 4.0.3. Need help ASAP!
If I do the same
