JPEG via Sockets
dudeck
Hi, here is code of Java app, which gets frames from webcamera and send them as jpegs through sockets.
Code:
import java.awt.Dimension;
import java.awt.image.BufferedImage;
import java.io.BufferedOutputStream;
import java.io.DataOutputStream;
import java.io.IOException;
import java.io.OutputStream;
import java.net.ServerSocket;
import java.net.Socket;
import java.util.Vector;
import javax.imageio.ImageIO;
import javax.media.Buffer;
import javax.media.CannotRealizeException;
import javax.media.CaptureDeviceInfo;
import javax.media.CaptureDeviceManager;
import javax.media.Format;
import javax.media.Manager;
import javax.media.MediaLocator;
import javax.media.NoDataSourceException;
import javax.media.NoPlayerException;
import javax.media.Player;
import javax.media.control.FrameGrabbingControl;
import javax.media.format.RGBFormat;
import javax.media.format.VideoFormat;
import javax.media.protocol.CaptureDevice;
import javax.media.protocol.DataSource;
import javax.media.util.BufferToImage;
 * A disposable class that uses JMF to serve a still sequence captured from a
 * webcam over a socket connection. It doesn't use TCP, it just blindly
 * captures a still, JPEG compresses it, and pumps it out over any incoming
 * socket connection.
 * @author Tom Gibara
public class WebcamBroadcaster {
    public static boolean RAW = false;
    private static Player createPlayer(int width, int height) {
        try {
            Vector<CaptureDeviceInfo> devices = CaptureDeviceManager.getDeviceList(null);
            for (CaptureDeviceInfo info : devices) {
                Format[] formats = info.getFormats();
                for (Format format : formats) {
                    if (!(format instanceof RGBFormat)) continue;
                    RGBFormat rgb = (RGBFormat) format;
                    Dimension size = rgb.getSize();
                    if (size.width != width || size.height != height) continue;
                    if (rgb.getPixelStride() != 3) continue;
                    if (rgb.getBitsPerPixel() != 24) continue;
                    if ( rgb.getLineStride() != width*3 ) continue;
                    MediaLocator locator = info.getLocator();
                    DataSource source = Manager.createDataSource(locator);
                    source.connect();
                    System.out.println();
                    ((CaptureDevice)source).getFormatControls()[0].setFormat(rgb);
                    return Manager.createRealizedPlayer(source);
        } catch (IOException e) {
            e.printStackTrace();
        } catch (NoPlayerException e) {
        } catch (CannotRealizeException e) {
        } catch (NoDataSourceException e) {
        return null;
    public static void main(String[] args) throws NoPlayerException, CannotRealizeException, IOException {
        int[] values = new int[args.length];
        for (int i = 0; i < values.length; i++) {
            values[i] = Integer.parseInt(args[i]);
        WebcamBroadcaster wb;
        if (values.length == 0) {
            wb = new WebcamBroadcaster();
        } else if (values.length == 1) {
            wb = new WebcamBroadcaster(values[0]);
        } else if (values.length == 2) {
            wb = new WebcamBroadcaster(values[0], values[1]);
        } else {
            wb = new WebcamBroadcaster(values[0], values[1], values[2]);
        wb.start();
    public static final int DEFAULT_PORT = 9889;
    public static final int DEFAULT_WIDTH = 320;
    public static final int DEFAULT_HEIGHT = 240;
    private final Object lock = new Object();
    private final int width;
    private final int height;
    private final int port;
    private boolean running;
    private Player player;
    private FrameGrabbingControl control;
    private boolean stopping;
    private Worker worker;
    public WebcamBroadcaster(int width, int height, int port) {
        this.width = width;
        this.height = height;
        this.port = port;
    public WebcamBroadcaster(int width, int height) {
        this(width, height, DEFAULT_PORT);
    public WebcamBroadcaster(int port) {
        this(DEFAULT_WIDTH, DEFAULT_HEIGHT, port);
    public WebcamBroadcaster() {
        this(DEFAULT_WIDTH, DEFAULT_HEIGHT, DEFAULT_PORT);
    public void start() throws NoPlayerException, CannotRealizeException, IOException {
        synchronized (lock) {
            if (running) return;
            MediaLocator ml = new MediaLocator("vfw://0");
            player = Manager.createRealizedPlayer(ml);
            if (player == null) {
                System.err.println("Unable to find a suitable player");
                return;
            player.start();
            control = (FrameGrabbingControl) player.getControl("javax.media.control.FrameGrabbingControl");
            worker = new Worker();
            worker.start();
            running = true;
    public void stop() throws InterruptedException {
            if (!running) return;
            if (player != null) {
                control = null;
                player.stop();
                player = null;
            stopping = true;
            running = false;
            worker = null;
        try {
            worker.join();
        } finally {
            stopping = false;
    private class Worker extends Thread {
        private final int[] data = new int[width*height];
        @Override
        public void run() {
            ServerSocket ss;
            try {
                ss = new ServerSocket(port);
                return;
            while(true) {
                FrameGrabbingControl c;
                    if (stopping) break;
                    c = control;
                Socket socket = null;
                try {
                    socket = ss.accept();
                    Buffer buffer = c.grabFrame();
                    BufferToImage btoi = new BufferToImage((VideoFormat) buffer.getFormat());
                    BufferedImage image = (BufferedImage) btoi.createImage(buffer);
                    if (image != null) {
                        OutputStream out = socket.getOutputStream();
                        if (RAW) {
                            image.getWritableTile(0, 0).getDataElements(0, 0, width, height, data);
                            image.releaseWritableTile(0, 0);
                            DataOutputStream dout = new DataOutputStream(new BufferedOutputStream(out));
                            for (int i = 0; i < data.length; i++) {
                                dout.writeInt(data[i]);
                            dout.close();
                        } else {
                            ImageIO.write(image, "JPEG", out);
                    socket.close();
                    socket = null;
                } finally {
                    if (socket != null)
                        try {
                            socket.close();
                            /* ignore */
            try {
                ss.close();
                /* ignore */
And this code is correct and works.
I've wrtitten this one to receive images (Android) and set them on ImageView:
Code:
package com.example.receivecamerajpeg;
import java.io.InputStream;
import java.net.UnknownHostException;
import android.os.Bundle;
import android.annotation.SuppressLint;
import android.app.Activity;
import android.graphics.drawable.Drawable;
import android.widget.ImageView;
@SuppressLint("ParserError")
public class Receiver extends Activity {
    Socket socket;
    InputStream is;
    ImageView imageView;
    @SuppressLint({ "ParserError", "ParserError" })
    @Override
    public void onCreate(Bundle savedInstanceState) {
        setContentView(R.layout.activity_receiver);
        imageView = (ImageView) findViewById(R.id.imageView1);
        try {
            socket = new Socket("192.168.1.102", 9889);
            is = socket.getInputStream();
            Drawable d = Drawable.createFromStream(is, null);
            imageView.setImageDrawable(d);
            is.close();
            socket.close();
        } catch (UnknownHostException e) {
            // TODO Auto-generated catch block
But it's not works... Temporary I want to receive one picture and set it on ImageView. After I want to repaint it always when app receive picture from stream.
Does anyone know how to fix it?
