I'm developing a project with data base connection into the code.
When i run the project and try to save inserted data, eclipse report this errors:
Buffer Error - Error Converting Result java.lang.nullpointerException
Json Parsen - Error Parsing Data org.jsonexception
end of input of character 0 of
And here it goes the following code:
JsonParsen.java
MainActivity.java
NewProductActivity.java
JsonParsen.java
Code:
package com.example.androidhive;
import java.io.BufferedReader;
import java.io.IOException;
import java.io.InputStream;
import java.io.InputStreamReader;
import java.io.UnsupportedEncodingException;
import java.util.List;
import org.apache.http.HttpEntity;
import org.apache.http.HttpResponse;
import org.apache.http.NameValuePair;
import org.apache.http.client.ClientProtocolException;
import org.apache.http.client.entity.UrlEncodedFormEntity;
import org.apache.http.client.methods.HttpGet;
import org.apache.http.client.methods.HttpPost;
import org.apache.http.client.utils.URLEncodedUtils;
import org.apache.http.impl.client.DefaultHttpClient;
import org.json.JSONException;
import org.json.JSONObject;
import android.util.Log;
public class JSONParser {
static InputStream is = null;
static JSONObject jObj = null;
static String json = "";
// constructor
public JSONParser() {
// function get json from url
// by making HTTP POST or GET mehtod
public JSONObject makeHttpRequest(String url, String method,
List<NameValuePair> params) {
// Making HTTP request
try {
// check for request method
if(method == "POST"){
// request method is POST
// defaultHttpClient
DefaultHttpClient httpClient = new DefaultHttpClient();
HttpPost httpPost = new HttpPost(url);
httpPost.setEntity(new UrlEncodedFormEntity(params));
HttpResponse httpResponse = httpClient.execute(httpPost);
HttpEntity httpEntity = httpResponse.getEntity();
is = httpEntity.getContent();
}else if(method == "GET"){
// request method is GET
String paramString = URLEncodedUtils.format(params, "utf-8");
url += "?" + paramString;
HttpGet httpGet = new HttpGet(url);
HttpResponse httpResponse = httpClient.execute(httpGet);
} catch (UnsupportedEncodingException e) {
e.printStackTrace();
} catch (ClientProtocolException e) {
} catch (IOException e) {
try {
BufferedReader reader = new BufferedReader(new InputStreamReader(
is, "iso-8859-1"), 8);
StringBuilder sb = new StringBuilder();
String line = null;
while ((line = reader.readLine()) != null) {
sb.append(line + "\n");
is.close();
json = sb.toString();
} catch (Exception e) {
Log.e("Buffer Error", "Error converting result " + e.toString());
// try parse the string to a JSON object
try {
jObj = new JSONObject(json);
} catch (JSONException e) {
Log.e("JSON Parser", "Error parsing data " + e.toString());
// return JSON String
return jObj;
MainActivity.java
Code:
import android.app.Activity;
import android.content.Intent;
import android.os.Bundle;
import android.view.View;
import android.widget.Button;
public class MainScreenActivity extends Activity{
Button btnViewProducts;
Button btnNewProduct;
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.main_screen);
// Buttons
btnViewProducts = (Button) findViewById(R.id.btnViewProducts);
btnNewProduct = (Button) findViewById(R.id.btnCreateProduct);
// view products click event
btnViewProducts.setOnClickListener(new View.OnClickListener() {
@Override
public void onClick(View view) {
// Launching All products Activity
Intent i = new Intent(getApplicationContext(), AllProductsActivity.class);
startActivity(i);
btnNewProduct.setOnClickListener(new View.OnClickListener() {
@Override
// Launching create new product activity
Intent i = new Intent(getApplicationContext(), NewProductActivity.class);
startActivity(i);
Code:
import java.util.ArrayList;
import org.apache.http.message.BasicNameValuePair;
import android.app.ProgressDialog;
import android.os.AsyncTask;
import android.widget.EditText;
public class NewProductActivity extends Activity {
// Progress Dialog
private ProgressDialog pDialog;
JSONParser jsonParser = new JSONParser();
EditText inputName;
EditText inputPrice;
EditText inputDesc;
// url to create new product
private static String url_create_product = "http://127.0.0.1/android_connect/create_product.php";
// JSON Node names
private static final String TAG_SUCCESS = "success";
@Override
setContentView(R.layout.add_product);
// Edit Text
inputName = (EditText) findViewById(R.id.inputName);
inputPrice = (EditText) findViewById(R.id.inputPrice);
inputDesc = (EditText) findViewById(R.id.inputDesc);
// Create button
Button btnCreateProduct = (Button) findViewById(R.id.btnCreateProduct);
// button click event
btnCreateProduct.setOnClickListener(new View.OnClickListener() {
@Override
// creating new product in background thread
new CreateNewProduct().execute();
* Background Async Task to Create new product
class CreateNewProduct extends AsyncTask<String, String, String> {
* Before starting background thread Show Progress Dialog
@Override
protected void onPreExecute() {
super.onPreExecute();
pDialog = new ProgressDialog(NewProductActivity.this);
pDialog.setMessage("Creating Product..");
pDialog.setIndeterminate(false);
pDialog.setCancelable(true);
pDialog.show();
* Creating product
protected String doInBackground(String... args) {
String name = inputName.getText().toString();
String price = inputPrice.getText().toString();
String description = inputDesc.getText().toString();
// Building Parameters
List<NameValuePair> params = new ArrayList<NameValuePair>();
params.add(new BasicNameValuePair("name", name));
params.add(new BasicNameValuePair("price", price));
params.add(new BasicNameValuePair("description", description));
// getting JSON Object
// Note that create product url accepts POST method
JSONObject json = jsonParser.makeHttpRequest(url_create_product,
"POST", params);
// check log cat fro response
Log.d("Create Response", json.toString());
// check for success tag
try {
int success = json.getInt(TAG_SUCCESS);
if (success == 1) {
// successfully created product
startActivity(i);
// closing this screen
finish();
} else {
// failed to create product
return null;
* After completing background task Dismiss the progress dialog
protected void onPostExecute(String file_url) {
// dismiss the dialog once done
pDialog.dismiss();
