ragingmullet
I recently downloaded the juice defender app and am a little confused about the toggle Mobile data widget. If I understand correctly, the purpose of the juice defender settings are to disable and reenable the mobile and wireless connectivity. Problem is, when I use the toggle Mobile data widget it overrides the setting. So...I guess my question is: after you use the widget to turn mobile data on or off, how do you give the juice defender setting (balanced, aggressive) precedence again?
