Just a few questions while im at work...
1. Where exactly are the files located when u put them on your phone from the computer? And don't say the SD card.
2. My side 'buttons' on my Droid (the back, menu, home, and search buttons) no longer make a click noise when I touch them. And yes all my volumes are on.
3. How do I organize my pictures on the Droid?
That's it for now.
1. But thats where they are stored, what do you really want to know??
2. dont own a droid so someone else can help.
3. Just create a folder named whatever you want on your sd card, then put pictures in it. This folder name then becomes the album name on your phone. You can do it via the PC, or using the app called astro file manager
I mean I want to access the files on my phone that I just put on there from my computer. Like say I put a PDF file on there and I want to read it on my phone, how would I do this? Or a Movie, or ne thing.
BTW; thanks for the reply.
1)Maztor, get Astro File Manager to easily view contents on SD card.
3) Easiest way would to be connected to PC and while in your SD card make a folder called Pictures, than in there make folders with names you want (example: Christmas 09, Las Vegas 10, etc) and put the pics in there. You can do the same with Astro File Manager but it be a bit faster on the PC. Than when you go into your gallery on your phone you will see the folders with the names and pictures within.
