Just having battery issues?
K so I have had my x10 now for 4 months with rogers. The battery was fine on the 2.1 update lasted about 2 days. Now i have updated to the new multi touch version and i am lucky if it last 10 hours.
I have rooted the device. I have deleted moxier,timescape,mediascape, face rec, and others. My display is set to as low as it can go i also have GPS and sync turned off. I also turn off bluetooth and wifi when i am not using it.
I also started from scratch by reinstalling rom and still really bad. i can leave it on over night after it has been fully charged and when i wake up in the morning i have like 20% left.
Just wondering if there is something in the new firmware causing this battery issue.
Thanks.
