Root Just installed cwm recovery but need help!!!!
chago360
I hold the volume up but in the top left corner it says "i boot to recovery mode by key 1" Can someone please help!!!!!
Try downloading Power Menu from the Google store, it's free and makes it a little easier to boot into recovery mode.
It's supposed to say that in the top left corner, though. Except it's just "boot to recovery mode by key". Usually when that shows up is when I let go of the buttons.
I just downloaded and tried it. Pretty slick! I was wondering what that icon was for on your home screen this morning.
Dont know if this is the right place to post this, but I tried to do the MD12 update after flashing stock recovery( I was already rooted & had cwm) now it wont boot into recovery at all,only download mode.....in recovery I get the blue flash then nothing
Any suggestions would be appreciated
Thanks in advance!!
Thanks in advance!!
Try flashing mrg's cwm 6.0.3.6 (not test 8)
Same basic thing happened to me, flashing that cleared it right up.
