Help K1 camera viewfinder green
gsxrdad
I've had my K1 for a week now , I'm updated to 3.2.1 and havent tried camera since the first day, it worked fine that day and we took several pictures. When I open the camera now the viewfinder for the rear camera flashes green with various desktop icons visible within the green. The viewfinder when switched to front facing is fine and camera functions and captures normally. I cleared the cameras cache and even downloaded a few camera apps, all the other app screens are also green on the rear camera. I really don't want to do a master reset as I've got the K1 set up where we all like it, and don't really need the camera but the kids like it . Any ideas ? Thanks
I'm thoroughly stumped? Sounds like you have a piece of green tape stuck over the lens...you'll probably have to do a factory reset....at least you can take a screen shot of your panels prior to doing the reset..
Keep us posted on if it worked...
Tried the "factory data reset" it didnt help the problem , I noticed after the reset all data and apps were gone but am still at 3.2.1 I expected to go back to 3.o is this normal ? I'm a week over for returning it to Staples , called Lenovo and I'll have to mail it back . It's been a tough tablet month for us, Just got our HP touchpad back from a cracked case repair that HP lost for a month, only to get it back and 1/3 of the touchscreen unresponsive Both are getting mailed back tomorrow Thanks for your help I hope Lenovo repair is better than HP
I had the same issue, but with the front cam not the back. I sent it in to be fixed. I will see what they say the issue is.
I will post back with my findings.
How do you turn on the rear camera to take a self picture? I have the k1 for 5 months and never knew how to turn on the rear camera. Dont even know if mind has the green problem.
there is an icon at the right bottom corner in the original carmera-app. I don't know how you switch the camara in other 3rd party apps.... but I've read, that in skype for example there is also that possibility.
and you'll have the 'green problem' if you upgraded your tablet to android 3.2.1
tobias
Thank you for letting me know how to turn on the rear camera on my k1. It works great and i have the latest system update 3.2.1 . There are no green flashes or flashing icons. I guess i lucked out. Thank you again for your help now i can take self pics for my friends
