Help k2_cl camera orientation issue
So my phone is a k2_cl rooted, s-off, 4.2.2, stock kernel, with the one_sv_swapper mod. Anyways, I'm having issues with the stock camera saving the orientation of some photos incorrectly. it seems to be random. For instance, I'll take 3 pictures (from the same session, ie 15 seconds apart) in landscape orientation, 2 will be saved as 2592x1552 and one will be saved as 1552x2592 even though the camera hasn't even been rotated. Videos are being saved incorrectly (backwards resolution) almost 75% of the time. I've even had the image saved upside down a few times. Anybody else seen this type of problem?
its a glitch that occurs when you modify the system sadly.if you use camerazoom fx it has a positioning fix that worked for me.it seemed to happen after the one swap mod for some reason.another suggestion would be to go into recovery and choose fix permissions.that shouldnt change the swap mod but it should clear up some improper placements.btw good to see you chopper
Crap that's not good. I've been having trouble with icons disappearing and notifications lately too. Not receiving notifications and ringtone association changing seemingly random. I'm guessing it wouldn't be a stretch to think they are swapper related issues as well. I'll give it a couple of days or so to see if the fix permissions has any effect. I just don't think I can give up the internal memory and go back to pre-swapper. I'm not desperate to go buy a new phone, but I really thought the swapper mod would get me by for another year or so before I bought a new one. Thanks for all your help frost.
