Hi,
I have flashed to KaosFroyo 2.2 v35.1.
Everything is fine and the best thing of all is the amazing Power Control widget with all the customization of the widget.
But!:
I have Exchange 2003 Outlook recurring events created in Outlook. If I use the phone's calendar to delete today's event only from a weekly-recurring event ("Delete this event only"), it doesn't sync with Outlook. In other words, after a sync and check Outlook, I still see the event I deleted using the phone calendar. The other way around, it works fine (if I delete an event in Outlook, it updates on my phone to where I don't see it). Any tips/ideas?
Is there a place I can enter this as a bug for KaosFroyo 35.1?
Thank you!!
But!:
Thank you!!
