The phone needs to "see" the charger's modified data pins ... so the two data wires in the cable have to be intact.I use the same charger but I use a USB that is longer than the white original. I don't get any messages. Does the "wire" matter?
I use the same charger but I use a USB that is longer than the white original. I don't get any messages. Does the "size and length" matter?
... but I disagree about the length. The longer and thinner the cable the higher the resistance and therefore the lower the current.
I have several wall charger units. Huawei, Nokia and Samsung. Charge amperage varies between 500mA - 750 - 800 - 1.0 and up to 2.0A. The White Samsung unit is 2.0A and charges the S4 in under 2 hours. The others take anything up to 5 hours to fully charge the battery. It does pay to use the correct type along with the USB charge cable supplied as OEM.Fast charging
The device has a built-in fast charging feature. You can use this feature to charge the battery
more quickly while the device or its screen is turned off.
About Fast charging
• Fast charging uses battery charging technology that charges the battery faster by
increasing the charging power. The device supports Samsung’s Adaptive fast charging
feature and Qualcomm Quick Charge 2.0.
• To use Fast charging on your device, connect it to a battery charger that supports
Adaptive fast charging or Quick Charge 2.0.
Increasing the charging speed
To increase the charging speed, turn the device or its screen off when you charge the battery.
• While charging the battery when the device is turned off, the icon appears on the
screen.
• You cannot use the fast charging feature when the screen is turned on. Turn off the
screen to increase the charging speed.
• You can check the remaining charge time on the screen. The actual remaining time
may vary depending on the charging conditions.
• You cannot use the built-in fast charging feature when you charge the battery
using a standard battery charger.
• If the device heats up or the ambient air temperature rises, the charging speed may
decrease automatically. This is a normal operating condition to prevent damage to
the device.
