Root Keep old zip files on sd?
goowakjai
If i install new ROM, i have CM6 installed now, but had CM6 alpha installed previously. Do i need to keep the CM6 zip file on my sd card or can i delete it.
You can go ahead and delete it. What I did was make a folder on my PC to store all of the files I've collected on my N1 adventures. I save everything in there and work out of it so that if I ever decide to go back to something I had before, I won't have to go searching for the file through the internet or dealing with dead links
