Help Keeps forgetting bluetooth settings
I have a Plantronics Voyager Pro+ headset and it automatically connects to both phone audio and media audio. I can go into the bluetooth settings and reset it to only connect via phone audio when I turn the bluetooth off and then back on - it reconnects both again. Very annoying when I have no sound and I find it's going to my bluetooth. Also, this must be draining my battery more than it needs to. This didn't used to happen with my incredible.
Any ideas? I wouldn't mind disabling A2DP completely since I don't need it, but I haven't been able to figure out how. I tried changing settings in /etc/bluetooth/audio.config but nothing has helped.
Is anyone else having this problem? Is there a solution? Will another ROM fix this? CM7 perhaps?
A little late to respond, but I am having that problem, too, with BlueAnt S4.
Has anyone figured out how to make this setting stick? After using phone my music comes out of the speakerphone (it's also connected through 3.5mm to my car audio, which of course is preferable).
My workaround is to turn off BlueAnt and back on, but that's annoying.
