[DEV][REPOST][SCRIPTS][TWEAKS] TurboBoost™-V8 --GB running a ICS Heart-- - xda-developers
would this work for our phones?
just flash through cwm? after mounting system of course. will this affect my ROM negatively? just curious... this new kernel thing is new for me and the admire alike
I know but my stuff always freezes then force closes for no reason at all. Probably because i was using RAM Scripts right? Because it says it is NOT recommended to use that when having ram scripts. Oh well. Back to smurfed out i guess!
smurfed out removes tweaks that might interfere with it. So everything will be ok since you can unsmurf!
no, Unless turbo boost has a tweak that might interfere with it it'll delete only that one tweak, but it'll save a backup on your SD, in case you want to Unsmurf it'll return your old files. Or do it the easy way out, Do smurfed out first, then flash turbo boost.Not recommended, be sure to backup first, Tell me the results!
is there a link to this smurfed
so whats better these smufted or the turbo boost
